Number of Waypoints Allowed in a Route on an Automotive Device
Many of Garmin's automotive products allow you to create a multiple-point route. This function allows you to route from point to point without having to enter a new destination after each stop. Your device has the Routes tool and can have a maximum of 200 waypoints per route.
If the number of waypoints you want on your route exceeds that device's limitation, it is recommended that you create a separate route or trip for each leg. For example, if you are traveling across the country over several days, it is recommended that you create a separate route for each day.
