Pairing Compatible Rangefinders to a GPSMAP 67 with Applied Ballistics
The GPSMAP® 67 handheld navigator with Applied Ballistics can receive range data automatically from compatible rangefinders, as well as provide a ballistics solution back to the rangefinder.
- Bushnell Nitro 1800
- Leica Geovid Pro 10x42 AB Plus
- Leica Geovid Pro 32
- Safran Vectronix Terrapin X
- Sig Sauer KILO 2400 BDX
- Sig Sauer KILO 3000 BDX
- Sig Sauer KILO 3K
- Sig Sauer KILO 4K
- Sig Sauer KILO 5K BDX
- Sig Sauer KILO 6K HD
- Sig Sauer KILO 8K-ABS
- Sig Sauer KILO 10K-ABS HD
- Vortex Fury HD 5000 AB
Adding a Ballistic Sensor
To pair a device with Applied Ballistics to a rangefinder, first put the compatible rangefinder in AB External pairing mode. AB External mode may also need to be enabled to send range data to the compatible Garmin device. Use the owner's manual for your rangefinder for instructions.
- On the GPSMAP 67 handheld press the Menu button twice to open the main menu.
- Highlight Setup and press Enter.
- Use the Directional Key to highlight Sensors.
- Press Enter to select.
- Use the Directional Key to highlight Applied Ballistics.
- Highlight Applied Ballistics and press Enter.
- Highlight + AB Sensor and press Enter.
- Highlight the rangefinder you are trying to add and press Enter.
NOTE: If using Vectronix rangefinders select Vectronix from the sensor list instead of Applied Ballistics.
