Setting Gear Reminders in the Garmin Dive App
When adding certain types of gear in the Garmin Dive™ app, such as tanks or regulators, you can enter service date information so you can receive notifications when your gear needs to be serviced. Notifications will need to be enabled in the Garmin Dive app in order to receive reminders about the gear you have added. For more details on adding or editing gear see - Adding and Managing Gear in the Garmin Dive App.
Notification Settings
  1. Open the Garmin Dive app.
  2. Select More.
  3. Select Settings.
  4. Select Push Notifications.
  5. Select Service Reminders to toggle the switch to the right for On.
    NOTE: You must also have the Allow Push Notifications toggle set to On in order to receive any push notifications.
If you are not getting notifications from the Garmin Dive app on your phone, confirm that your phone permissions are setup to allow notifications for the Garmin Dive app.
  2. Select More.
  3. Select Settings.
  4. Select Phone Permissions.
  5. Confirm Notifications is On.
  6. Select Manage Permissions to enable Notifications if needed.
