Getting Started With the Descent T2 Transceiver
The links below will help you learn about and get started with your Descent™ T2 transceiver. Your transmitter helps you wirelessly monitor air tank pressure during a dive. To ensure proper setup and best performance, it is strongly recommended that you complete the first time installation and setup at a dive shop. You should fully test the transceiver installation above and below water before using it during a dive. The video below will give you an overview on how to get started with your Descent T2 transceiver.
Compatible Garmin Devices
Your Descent T2 transceiver can be paired with any of the following dive computers. See Garmin Dive Computer and Air Integration Transmitter Compatibility for more information about the compatible dive computers.
  • Descent™ Mk2i watch
  • Descent™ Mk3i - 43mm | Descent™ Mk3i - 51mm watches
  • Descent™ X50i dive computer
Setup
Using the Descent T2 Transmitter
Troubleshooting
