Improving the Battery Life of Garmin inReach Products
There are a few settings that can noticeably contribute to overall battery performance when using an inReach® satellite communicator.
Enabling or disabling settings, as well as adjusting timed intervals, will all affect the expected battery life . These settings should be adjusted based on usage before going out into the field.
NOTE: Before you address some of the functions that affect battery life, first ensure your inReach handheld firmware is up to date. See Related for steps.
Features and Conditions That Impact Battery Life
Backlight
Connected to Phone
View of the Sky
  • inReach handhelds are designed to be used outdoors. We suggest testing the device before you head out on your trip, but do so outside. If the device is powered on indoors, the battery will drain noticeably faster as the handheld will not be able to find the signal for sending/receiving messages or tracking points. Additionally, the handheld will have to try a lot harder to find a GPS signal.
Send Interval or Tracking
Log Interval or Recording Controls
Low Power Modes: Extended Tracking or Expedition Mode
NOTE: Hardware and software improvements have eliminated the need for Extended Tracking or Expedition Mode settings on the inReach Messenger and inReach Mini 2.
Extended Tracking
Extended Tracking will disable several features of the inReach SE+/Explorer+ and inReach Mini (listed below) to conserve the battery life of the device for tracking.
  • Bluetooth
  • Message Listens
  • Navigation
  • Log Interval
If any of these options are manually turned on, after Extended Tracking is enabled, the device will automatically leave the Extended Tracking mode.
Extended Tracking does not change or affect the track Send Interval for the inReach device.
While in Extended Tracking mode, the device will go into a "sleep" mode and the screen will appear to be turned off. Tapping the power button will "wake" the device up to be used as normal.
For more information on the Extended Tracking setting, select your device below:
Expedition Mode
Expedition Mode features for the GPSMAP 66i/67i/86i/86sci/H1i Plus and Montana 700i/710i750i/760i:
  • Track points are dropped via a smart recording mode that determines the best interval to log based off movement and other factors.
  • Track log detail will be reduced when the setting is enabled.
  • Bluetooth connections are disabled.
  • ANT + connections to Heart Rate monitors or other sensors are disabled.
  • Using the Expedition Mode (with a clear view to the sky) can increase the device’s battery life by days or even weeks.
  • Expedition Mode allows the user to prolong the battery life of the GPSMAP 66i/67i/86i/86sci/H1i Plus and Montana 700i/710i750i/760i. When enabled, the screen will turn off and the green light next to the power button will occasionally flash to let you know the unit is still powered on and recording data.
While in Expedition Mode, the device will go into a "sleep" mode and the screen will appear to be turned off. Tapping the power button will "wake" the device up to be used as normal.
For more information on the Expedition Mode setting, select your device below:
Temperature
  • All devices that use batteries are subject to reduced battery run times in cold conditions. Conditions below freezing will significantly reduce the battery capacity and charging can only occur above freezing.
Connected with Additional Sensors or Devices
  • Connecting the handheld with a watch through the inReach Remote feature will create an additional drain on the battery. Another example would be connecting the GPSMAP 66i/67i/86i/86sci/H1i Plus or Montana 700i/710i/750i/760i with a tempe™ sensor. If the additional sensor/device is not in use, it is a good idea to disable the connection so the handheld is not searching for the additional information unnecessarily. For instructions, select your device below:
    GPSMAP 66i, 67i, 86i, and 86sci Outdoor Handhelds
    1. Press MENU twice to access the main menu.
    2. Select Setup.
    3. Select Sensors.
    4. Select an option:
      • Fitness: Select a sensor type, then select Off.
      • Tempe Sensor: Select Off.
      • XERO: Select Status to toggle the sensor Off.
      • Applied Ballistics: Only available on the GPSMAP 67i. Select a sensor type, then select Off.
      • inReach Remote: Select Enabled to toggle the sensor Off.
    GPSMAP H1i Plus Outdoor Handheld
    1. Press MENU twice, then select 9 Squares to access the apps list.
    2. Select Settings.
    3. Select Connectivity.
    4. Select Sensors & Accessories.
    5. Select an option:
      • DogTrack: Select Off.
      • Applied Ballistics: Select a sensor type, then select Off.
      • CIQ Sensor: Select Off.
    inReach Messenger Device
    1. From the home page, press Left Arrow Button or Right Arrow Button to scroll through the main menu options, then select SETTINGS Wrench.
    2. Select inReach Remote Remote icon.
    3. Select Status to toggle the sensor Off.
    inReach Messenger Plus Device
    1. From the home page, press Left Arrow Button or Right Arrow Button to scroll through the main menu options, then select SETTINGS Gear Wheel.
    inReach Mini Device
    1. From the home page, press OK to open the main menu.
    2. Select Setup.
    3. Select ANT+.
    4. Select Status.
    5. Select Off.
    inReach Mini 2 Device
    2. Select Settings.
    3. Select inReach Remote.
    4. Select Status to toggle the sensor Off.
    Montana 700i, 710i, 750i, and 760i Outdoor Handhelds
    1. Select Home to access the main menu.
    2. Select Setup.
    3. Select Sensors.
      • DogTrack: Select Status > Off.
Altimeter Settings
The following devices have the ability to adjust when Barometric Altimeter pressure trending information is saved for elevation.
  • GPSMAP 66i | GPSMAP 67i | GPSMAP 86i | GPSMAP 86sci
  • Montana 700i | Montana 710i | Montana 750i | Montana 760i
Based on the setting this can cause battery drain. See the following steps to help improve battery life.
  1. From the main menu, select Setup.
  2. Select Altimeter.
  3. Select Pressure Trending.
  4. Select Save When Power is On.
    Save When Power is On saves altimeter information only when the device is powered on.
    Save Always is always looking for pressure even when the device is powered off.
Expected Battery Life for inReach Products
NOTE: Unless otherwise stated, battery life estimates are with full sky view and can be significantly impacted by obstructions or tree cover.
inReach Messenger Satellite Communicator
ProfileRecordingSendingExtended TrackingBattery (hrs)
Connected to Phone (Default)Not Applicable10-minNot Applicable2
Full Sky View: Up to 672
Moderate Tree Cover: Up to 336
Connected, Expedition or Premium PlanNot Applicable2-min1Not Applicable2
Full Sky View: Up to 144
Moderate Tree Cover: Up to 72
inReach Messenger Plus Satellite Communicator
Connected to Phone, Low Power Messaging Mode (Default)Standard10-minNot Applicable2
Up to 600
Connected to Phone, Performance Messaging Mode Standard10-minNot Applicable2
Up to 110
Connected, Low Power Messaging Mode, Expedition or Premium PlanStandard2-min1Not Applicable2
Up to 120
Connected, Performance Messaging Mode, Expedition or Premium PlanStandard2-min1Not Applicable2
Up to 70
inReach Mini Satellite Communicator
ProfileLoggingSendingExtended TrackingBattery (hrs)
Connected to Phone (Default)Off10-minOff90
Standalone, No PhoneOff30-minOn575
Connected, Expedition or Premium Plan1-sec2-min1Off25
inReach Mini 2 Satellite Communicator
Connected to Phone (Default)Standard10-minNot Applicable2
Full Sky View: Up to 336
Moderate Tree Cover: Up to 96
Connected to PhoneHigh Detail10-minNot Applicable2
Full Sky View: Up to 120
Moderate Tree Cover: Up to 48
Connected to PhoneStandard30-minNot Applicable2
Full Sky View: Up to 720
Moderate Tree Cover: Up to 240
inReach SE®+ and inReach Explorer®+ Satellite Communicators
Connected to Phone (Default)1-min10-minOff115
Standalone, No PhoneOff30-minOn1100
Connected, Expedition or Premium Plan1-sec2-min1Off50
GPSMAP® 66i, 86i, and 86sci Satellite Communicators
ProfileRecordingSendingExpedition ModeBattery (hrs)
Connected to Phone (Default)1-sec10-minOff35
Standalone, No PhoneSmart30-minOn225
GPSMAP® 67i Satellite Communicator
Connected to Phone (Default)1-sec10-minOff165
Standalone, No PhoneSmart10-minOn425
Connected, Expedition or Premium Plan1-sec2-min1Off120
GPSMAP® H1i Plus Satellite Communicator
Performance Messaging ModeSmart10-minOffUp to 48
Auto Select Satellite ModeSmartTracking OffOffUp to 145
Expedition ModeSmart10-minOnUp to 425
Expedition ModeSmartTracking OffOnUp to 840
Montana® 700i, 710i, 750i, 760i Satellite Communicators
Battery (hrs)
With Standard Lithium-ion Battery Pack
Battery (hrs)
With High Capacity Lithium-ion Battery Pack
Connected to Phone (Default)1-sec10-minOff1824
Standalone, No PhoneSmart30-minOn300400
Connected, Expedition or Premium Plan1-sec2-min1Off1520
Additional information on these settings and how to adjust them can be found in the owner's manual.
My Battery is Still Draining Rapidly
If battery drain continues after making some changes to settings, try returning the handheld to factory defaults and seeing how long the battery lasts on a full charge without pairing it to smartphone again.
If the battery lasts like it used to, then the battery drain would be the result of the choice of customized settings on the handheld, or Bluetooth-connected features.
1 2 minute tracking is only available with select inReach plans.
2 Hardware and software improvements have eliminated the need for Extended Tracking or Expedition Mode settings on the inReach Messenger series and inReach Mini 2.
Related
