Where Exported IFTA Reports are Saved on the dēzl OTR Devices
Exported IFTA reports can easily be viewed on a computer. The exported IFTA reports will display as an Excel style spreadsheet.
NOTE: IFTA reports are generated in a comma separated value (.csv) file format. An application such as Microsoft Excel, Google Sheets, or another spreadsheet editor application which supports .csv files is required for opening and viewing jurisdiction summaries and trip reports when connected to a computer.
The reports will appear unreadable or may not open at all if using an application that does not support .csv files.
To Export IFTA Reports on the Device:
dēzl™ OTR500 GPS navigator: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzl™ OTR610 and dēzl™ OTR710 GPS navigators: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzl™ OTR620 and dēzl™ OTR720 GPS navigators: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzl™ OTR700 GPS navigator: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzl™ OTR800 and dēzl™ OTR1000 GPS navigators: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzl™ OTR810 and dēzl™ OTR1010 GPS navigators: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzl™ OTR820 and dēzl™ OTR1020 GPS navigators: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzlCam™ OTR710 GPS navigator with camera: Follow steps 1-4 in your device's manual to export the IFTA reports.
dēzlCam™ OTR725 GPS navigator with camera: Follow steps 1-4 in your device's manual to export the IFTA reports.
NOTE: The exported IFTA file details (.csv files) cannot be viewed on the device itself.
To View Exported IFTA Reports on the Computer:
NOTE: A Windows computer must be used for these steps. See Automotive Device Compatibility with Garmin Mac Applications on macOS for more info.
1. Plug the dēzl into the computer
2. Hold down the Windows key + E on the keyboard
Click This PC in the new window if using Windows 10 or 11
3. Double-click the drive labeled with the device name
Windows 10 or 11: the drive will be listed under Devices and Drives.
Windows 7 and 8: the drive may be listed under Devices with Removable Storage or Portable Devices.
4. Double-click Internal Storage or Internal Garmin Storage
5. Open the Reports folder
- Open the Garmin folder first on the dēzl™ OTR800 and dēzl™ OTR1000.
6. Open the IFTA folder
7. The exported log files will now appear in the folder
If the Files Do Not Appear on the Computer See:
dēzl OTR500, dēzl OTR610, dēzl OTR620, dēzl OTR700, dēzl OTR710, dēzl OTR720, dēzl OTR820, dēzl OTR1020, dēzlCam OTR710, dēzlCam OTR725 : Exported IFTA Not Found in the Folder When Connected to a Computer.
dēzl OTR800 and dēzl OTR1000: Exported IFTA or Saved RODS Reports Not Found in the Folder When Connected to a Computer.
dēzl OTR810 and dēzl OTR1010: Exported IFTA or Saved RODS Reports Not Found in the Folder When Connected to a Computer.
