Tread Software Release Versions
The Tread® and Tread® - Base Edition GPS navigators receives software updates via Wi-Fi or by using the Garmin Express™ software.
Release Notes
Version 10.30
Release Date 6/29/2024
Added the option for users to add configurable PowerSwitch buttons to the map page.
Fixed an issue where trails would not display if public land maps were enabled.
Improved software stability.
Version 10.20
Release Date 8/25/2023
Added a "GPS Elevation" option to the elevation display.
Fixed an issue where the unit would not allow BirdsEye images to download.
Fixed an issue where custom maps placed on an SD card could not be read.
Fixed an issue that caused some safety camera types to not show in Australia.
Fixed an issue that cut off the first few seconds of playback of MP3 tracks to headsets.
Improved synching of track-to-route trips.
Version 10.10
Release Date 2/15/2023
- Added enhanced support for snowmobile trails and POIs on snowmobile-compatible devices.
- Various bug fixes and improvements.
Version 9.80
Release Date 8/4/2022
- Added support for Tread Audio.
Resolved miscellaneous issues.
Version 8.40
Release Date 6/9/2022
- Added support for BC 50.
- Minor bug fixes
Version 7.80
Release Date 4/27/2022
- Added support for a new digital traffic provider in Germany.
Version 7.70
Release Date 2/22/2022
- Improved stability
Version 7.40
Release Date 1/4/2022
- Reworked the Trip Planner app to be map based
- Redesigned the Track Recorder app
- Added turn by turn trail routing
- Added new vehicle profile characteristics
- Added larger BirdsEye file size downloads
- Added Group Ride Mobile support
- Improved coordinate searching
Version 6.90
Release Date 9/21/2021
- Group Ride Tracking issue fix
- Group Rider's Caller ID issue fix
Version 6.80
Release Date 8/19/2021
- Added support for Garmin dog trackers
- Various TOPO Pro render improvements
- Miscellaneous UI improvements
Version 6.50
Release Date 6/9/2021
- Improved the visibility of TOPO Pro elements
- Fixed an issue that caused pairing times with the Garmin PowerSwitch to be longer than normal
- Removed vehicle map matching
Version 6.10
Release Date 3/23/2021
- Fixed a connectivity issue with Garmin PowerSwitch
Version 5.90
Release Date 3/10/2021
- Improved the performance during group rides with 15 or more riders
- Improved the visibility of private parcel boundary lines in night mode
- Fixed an issue where the name of a saved track is lost after it is saved
