Pairing a Dog Tracking Handheld and Collar
The following instructions are for pairing dog tracking collars with the various dog tracking handhelds.
Pairing Collars
Select a dog tracking handheld option below for collar pairing instructions.
- Touch Dog List
- Touch Add Dog
- Touch Pair Collar
- Follow the on-screen instructions
- With the collar off (not required for T 5X, TT™ 15X, Alpha T20, and Alpha TT25 collars), press and hold the Power button on the collar until it emits two beeps (about 5 seconds), and then release. The status LED will flash green indicating the collar is ready to be paired.
- Use the keyboard to enter a dog name.
- Select Finish
Start with the collar powered off.
- On the Alpha 10 handheld, press the Menu button to go to the Main Menu
- Select Add Device
- Select Dog
- Select Pair Collar
- Follow the on-screen instructions:
- Select Done
NOTE: If both a Pro 550 Plus and a second, different model handheld (Alpha® models or Astro® 430), are being used at the same time, it is important to pair the collar to the Alpha or Astro handheld first. This ensures that the Alpha or Astro handheld can properly manage, and alert you to any communication ID conflicts that might prompt the need to change a collar communication ID number in the Alpha or Astro Dog List.
The Pro 550 Plus cannot change nor manage collar ID numbers, and cannot change or manage other communication settings.
Pairing a compatible collar to a Pro 550 Plus handheld
- Power on the handheld
- Select a color with the Toggle switch
NOTE: The dog collar will be assigned to this color - Turn the intensity dial to N
- Select the green Tone key
- With Pair Collar highlighted, select the green Tone key again
- Follow the on-screen instructions to select auto, tree, or point for the type of dog wearing the collar appears on the handheld device screen.
NOTE: You can cancel pairing by pressing the green tone key. - If the dog collar device is on, turn it off (not required for T 5X, TT™ 15X, Alpha T20, and Alpha TT25 collars)
- Hold the Power key on the dog collar until it emits two series of beeps (about 5 seconds), and then release the Power key. The status LED will flash green rapidly
The handheld vibrates and a checkmark appears on the screen when the devices have paired successfully.
- Ensure the dog collar is next to the handheld, turned on, and connected with satellites before you attempt to pair
- Press Dog
- Press Menu
- Highlight the Dog List and press ENT
- Highlight <Add New> and press ENT
- Select Yes
- Enter a name for the dog.
- Highlight Done
- Press ENTER
The following chart shows which dog tracking collars are compatible with the different Garmin dog tracking devices.
Dog Tracking Collars | Alpha® XL | Alpha® 300 & Alpha® 200 Plus | Alpha® 200 | Alpha® 10 | Alpha® 100 | Pro 550 Plus | Astro® 430 | Astro® 320 | Astro® 220 | Astro® 900 |
Alpha® TT 25 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ 1 | |||
Alpha® T 20 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||
TT™ 15x | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓1 | |||
T 5x | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | |||
TT™ 15 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓1 | ✓ 1,3 | ||
TT™ 15 mini | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓1 | ✓ 1,4 | ||
T 5 | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ 3 | ||
T 5 mini | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ 4 | ||
TT™ 10 | ✓ | ✓ | ✓1 | |||||||
DC™ 50 | ✓ 2 | ✓ | ✓ | |||||||
DC™ 40 | ✓ | ✓ | ||||||||
DC™ 30 | ✓ | ✓ | ||||||||
DC™ 20 | ✓ | ✓ | ||||||||
T 9 | ✓ |
1 Tracking and Training collars only provide tracking capability with handhelds that do not have training functionality
2 The DC 50 collar is only compatible with the Alpha 100 handheld after being paired with an Astro 430 handheld first
3 T 5 and TT 15 collars with software version 5.80 or later (remanufactured or exchanged/serviced collars after May 2022) are no longer compatible with the Astro 320 handheld
4 T 5 mini and TT 15 mini collars with software version 4.80 or later are no longer compatible with the Astro 320 handheld
Note: The following models are discontinued and Garmin no longer offers replacement services. Astro 320 and Astro 220 handhelds. TT™ 10, DC™ 20, 30, 40, and 50 collars
