Overlay BirdsEye Onto Other Map Products
Garmin devices utilize a map draw order to display maps. The draw order for BirdsEye imagery files can be adjusted with the BaseCamp™ program so they are displayed over or under other map products.
When BirdsEye files are set to display below other maps, roads and trails or other map details will be overlaid on top of the BirdsEye imagery. Alternatively, BirdsEye files can be set to display above other maps to completely obscure any roads and trails or other map details.
NOTE: BirdsEye Satellite Imagery and BirdsEye TOPO cannot be overlaid so as to see both at the same time.
Adjusting the Draw Order of a BirdsEye File in BaseCamp
Ensure you have an active BirdsEye subscription.
Launch BaseCamp.
If necessary, download a section of BirdsEye.
Double-click the desired BirdsEye file.
Adjust the Draw Order as desired.1
Close the BirdsEye Property window.
BaseCamp will now display the BirdsEye imagery at the selected draw order.
Adjusting the Draw Order of a BirdsEye File on a Garmin Device
Launch BaseCamp.
Connect your Garmin to the computer with a USB cable.
If necessary, download a section of BirdsEye imagery and transfer it to the Garmin.
Select the Internal Storage folder (Windows) of the Garmin device, or the Garmin device name under My Garmin Devices (Mac).
Close BirdsEye Property window.
Your Garmin device will now display the BirdsEye imagery at the selected draw order.
1 The higher the draw order number, the more clear the BirdsEye imagery will be over other map products.
