How to Add or Delete aircraft in FltPlan.com
To Add an Aircraft in FltPlan®.com Flight planning services :
- Select the Settings drop down menu on the left side of the web page.
- Select Edit Aircraft List.
- From this page, you can add a tail number and associated information. To add a call sign, enter it in the column on the right-hand side of the page.
- Press the button Save Changes at the bottom of the page when done.
Be Sure to Add ICAO Data Once You Input a New Aircraft.
- Go to the Settings drop down menu on the left side of the web page
- Enter the new aircraft's A/C ICAO Data.
To Remove an Aircraft in FltPlan.com:
- Select Settings on the left side of the screen.
- Next, select Edit Aircraft List.
- Delete the tail number from the box.
