My Device Shows As Registered But Not Paired in the Garmin Connect App
There are usually two scenarios in which you will see your device listed in the Garmin Connect™ app as 'Registered but not paired'. This includes:
  • Pairing your device using the Garmin Express™ program on a computer before setting it up with the app.
  • Uninstalling the Garmin Connect app on your phone and Reinstalling it without taking the proper steps to remove your previously paired device.
Red Box outlining a message Registered but not paired
To correct this issue follow these exact steps:
  1. Sign into the Garmin Connect app.
  2. Select SKIP (bottom of screen) if the app asks you to "Select Your Device".
  3. Select More (bottom right).
  4. Select Garmin Devices.
  5. Select the Name of your device under the section 'Registered but not Paired'.
  6. Select Add This Device.
  7. Place your Garmin® device into Pairing Mode. This allows the Garmin Connect app to find it.
    • Wearables: Pairing Mode is typically found with the steps below. For exact steps refer to your owner's manual.
      • Access the Settings menu.
      • Select Bluetooth®, Connectivity, or Phone.
      • Select Pair Phone or Pair Mobile Device.
    • Edge Cycling Computer: Pairing Mode is typically found with the steps below. For exact steps refer to your owner's manual.
      • Select Bluetooth or Phone.
      • Select Pair Phone or Pair Smartphone.
  8. Now you should have the Garmin Connect app and your Garmin Device searching for each other.
  9. When the Garmin Connect app finds your device select Connect It.
  10. When your phone prompts you, enter in the 6 digit code displayed on your Garmin Device screen.
    • This step should not have been completed prior to completing steps 1-10. If you did, you may get a pairing failed message and will need to remove the Garmin device from Bluetooth and complete the steps in this section again.
  11. Select Pair or OK.
  12. Select Allow for permissions, if asked.
  13. Complete the remaining on-screen prompts in the app to complete setup.
  14. Select Finish.
Related
