My inReach Mini 2 is in the Wrong Language
If your inReach® Mini 2 handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
You may receive prompts to pair and activate before being able to access other settings on the inReach Mini handheld. If this occurs, scroll to and select the second option in each of these prompts to skip pairing and activation, then proceed with the steps below. Pairing and activation can be completed later in Settings.
- If necessary, press
until you reach the home page:
- From the home page, press OK.
- Scroll down to the last item in the list, and select it.
- Select the sixth item in the list.
- Scroll to and select the desired language.
