Fusion® MS-UD755 Manual Software Updates
Fusion® MS-UD755 software version 1.21.41
as of October 18, 2018
Download (11.85 MB)
View installation instructions
Notes:
  • This firmware release also contains updates for DAB+ accessories and NRX remote controls.
  • NRX Series Remote 1.02.75
  • DAB+ Module STM32 1.01
  • DAB+ Tuner 4.05
  • USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
  • Accessory software updates (MS-NRX Series/MS-DAB100A): Once the stereo is updated the connected accessory MUST be updated from the 'update' menu in the 'settings' menu to be compatible with your Fusion Entertainment System
  • Please note this software does not work on the MS-AV750 or MS-UD750. If you require the software for either of these products, please manually search for it within the legacy section of our website.
Change History
Changes made from version to 1.21:
  • General bug fixes and improvements
  • HDMI compatibility with new TV issue resolved
  • USB long track issue resolved
  • Updated remote version
  • Updated DAB version
Installation Instructions
  1. Insert a blank USB flash drive formatted in FAT32 with a capacity of at least 4gb and no larger than 32gb into the PC/laptop
  2. Download the FusionMS-UD755 update file to the PC/laptop and open it
  3. Drag the Update folder onto the USB flash drive
    • The Update folder should now be the only folder on the USB flash drive
  4. Connect the USB flash drive to the USB Port of the stereo
  5. On the stereo, select Menu > Settings > Update > Update Software
  6. The DAB+ module and remotes can now be updated from the update menu if required
