Using a Bare Wire CHIRP Transducer with a Garmin GPSMAP 5x7xs, 7x1xs, 8x0xs or 10x0xs Series Device
Most CHIRP transducers compatible with Garmin products are sold with a connector head installed on the transducer cable. However, some Airmar transducers have bare-wire cables that can be connected to compatible Garmin chartplotters using a Garmin 8-pin Wire Block Adapter (part number 010-11613-00).
The GPSMAP devices listed below are compatible with bare-wire transducers that operate at a single CHIRP frequency range:
GPSMAP 527xs
GPSMAP 547xs
GPSMAP 721xs
GPSMAP 741xs
GPSMAP 820xs
GPSMAP 840xs
GPSMAP 1020xs
GPSMAP 1040xs
GPSMAP 8600xsv series
GPSMAP 8400xsv series
GPSMAP 12x3xsv series
GPSMAP 9x3xsv series
GPSMAP 7x3xsv series
GPSMAP 10x2xsv series
GPSMAP 12x2xsv series
Compatible transducers will only have one letter after the transducer model number, such as B75L, TM150M, B175H, etc. For example, an Airmar B75H with bare wires is compatible with these devices because it only operates at the High CHIRP frequency band; the Airmar B265LH is not compatible because it is designed to operate at both the Low and High CHIRP frequency bands.
Go to the Garmin Transducer Selection Guide for more information about transducer compatibility.
