"USB Device Not Recognized" Error when Connecting a Garmin USB Device to a Computer
Description
The error USB Device Not Recognized indicates that there is a communication issue between Windows and the Garmin device.
Resolution
To Troubleshoot and Resolve This Issue:
  • Plug the USB cable directly into the device (see video below)
    • Plugging the USB cable into the mount on the device will not allow the computer to recognize the device
  • Charge the battery on the device
  • Try connecting the device to a different USB port (see video below)
    • Avoid connecting through a USB hub, USB extension cable, keyboard, or monitor
    • Use a USB port on the back of the computer instead of the ports on the front or side if using a desktop computer
    • Try a port on the opposite side of the computer if available if using a laptop.
  • Try using a different USB cable (see video below)
  • Try another computer if available
    • Work computers may not allow the computer to recognize the device
  • Reboot the computer
The USB Device Not Recognized error should no longer display.
View the Following Video to Learn About Connecting Your Garmin Automotive Device:
Contact Product Support if the issue continues.
