Using the dēzl Headset with a Compatible dēzl Device
The dēzl™ Headset 100, dēzl™ Headset 110, dēzl™ Headset 200, and dēzl™ Headset 210 Premium Trucking Headsets can be used with your compatible device if they are both connected to the dēzl™ app. This allows navigation prompts and voice activated navigation to blend into the headset audio stream.
The dēzl™ app is required to update the headset and adjust some settings.
- This is the only method supported for using the dēzl™ Headset with the dēzl™ LGV500, dēzl™ OTR500, dēzl™ LGV610, dēzl™ OTR610, dēzl™ LGV620, dēzl™ OTR620, dēzl™ LGV700, dēzl™ OTR700, dēzl™ LGV710, dēzl™ OTR710, dēzl™ LGV720, dēzl™ OTR720, dēzl™ LGV820, dēzl™ OTR820, dēzl™ LGV1020, dēzl™ OTR1020, dēzlCam™ LGV710, dēzlCam™ OTR710, dēzlCam™ LGV725, and dēzlCam™ OTR725 GPS navigators.
- This method is recommended for using the dēzl™ Headset with the dēzl™ LGV800, dēzl™ OTR800, dēzl™ LGV810, dēzl™ OTR810, dēzl™ LGV1000, dēzl™ OTR1000, dēzl™ LGV1010, and dēzl™ OTR1010 GPS navigators.
Navigation Audio Handling:
- During an active call with a compatible device connected, the navigation prompts are disabled and will not interrupt the call.
- When streaming media audio from the phone with a connected compatible device, the streaming audio volume will lower slightly and the navigation prompt will be spoken.
Headset Volume
- When using the rocker to adjust the headset volume, the volume will only increase or decrease by 10% increments.
