Setting a Proximity Alarm on an eTrex 10, 20(x), 22x, 30(x), or 32x
The Proximity Alarm feature will display a Near Proximity Point message when you are within proximity to a specific location. For example, if you set a proximity alarm for a waypoint with a radius of two miles, the eTrex 10, 20(x), 22x, 30(x), or 32x will display a message once you are two miles from the waypoint.
To set up the proximity alarm on the eTrex:
- Press the Menu button twice
- Select Proximity Alarms*
- Select Create Alarm
- Select a category to choose a point from or select Use Map to choose a point directly from the map screen
- Select the specific location
- Enter the distance from the point at which you want to be alerted
- Select Done
The device will now display a message when you reach that distance from the location.
*The radius measurement (feet, yards, miles) can be changed before entering the proximity alarm. Please see related content for further instructions.
