Alpha 100 Screen Calibration
There are two ways to initiate a screen calibration on the Alpha® 100.
The first is to select Setup > Display > Calibrate Screen and follow the on-screen instructions.
If, however, you're having difficulty with using the screen an alternate way is to start with the Alpha 100 off. Press and hold the power button until the screen indicates a grid with a a dot stating Press dot. Press the dots until you receive Calibration Complete.
