Upgrading a GHP 20 to the Reactor 40
If you currently own an GHP 20, but would like to upgrade to the GHP Reactor, you would need to do the following:
Notes:
• If the boat currently has a GHC 10, it needs to be replace with a GHC 20 or GHC 50. The GHP Reactor is not compatible with the GHC 10.
• If the GHP SmartPump is upgraded for a SmartPump Version 2 and the boat has a GHP 20 CCU "Compass Ball", the GHP 20 CCU is not compatible wit the SmartPump V2 upgrade the GHP 20 CCU with a Reactor 40 .
GHP 20 SmartPump
Required Parts
Reactor 40 part # 010-11052-67
Interconnect Cable part # 010-11351-40
GHC 20 part # 010-01141-00 or the GHC 50 part # 010-02731-00
Installation Overview
Replace the GHP 20 CCU with the Reactor 40
Replace GHP 20 interconnect cable with the Reactor 40 interconnect cable
Connect the Reactor 40 to NMEA 2000 using existing cable
Connect the Shadow drive to the Reactor 40
Connect the buzzer to the Reactor 40
Leave tach wires unconnected
Leave yellow wire from GHC unconnected
GHP 20 Steer-By-Wire
Required Parts
Reactor 40 (Steer-by-Wire & Yamaha Helm Master) - 010-11052-65
GHC 20: 010-01141-00
Connect the interconnect cable to the Reactor 40 using existing cable
These parts can be purchased from any Garmin Marine Dealer. Find a local dealer with the Dealer Locator Tool.
