Setting up a Satori Smart Trainer
This FAQ will cover the installation process for setting up your Tacx Satori Smart trainer, including compatibility questions regarding axles and bicycles.
Out of Box and Installation
The following video will walk you through the unboxing process, trainer setup, and bike installation.
Axle Compatibility
Garmin Tacx smart trainers only support 10/12 mm axles. The Satori Smart will come with a standard universal quick release axle skewer. This skewer will work with most bikes that feature a quick release skewer.
Universal Axle Skewer
Some bikes (especially mountain bikes) use what is called a thru-axle. Thru-axles thread directly into the bike's frame in order to hold the rear wheel in place. In the event that you have a bike that features a thru-axle, you will need to purchase one separately.
Tacx Thru-Axles (sold separately)
What Size Thru-Axles Are Available for Purchase?
You can purchase thru-axle adapters in the following sizes. We've included general information about the type of hubs
- M10x1 metric fine thread (T1706)
- Suitable for hubs with axle skewer attachment 135×10 mm (various Swiss and Shimano types)
- M12x1 metric fine thread (T1707)
- Suitable for hubs with axle skewer attachment 142×12 mm (various DT Swiss and Shimano types)
- M12x1.75 standard threaded cartridge (T1708)
- Suitable for hubs with a Maxle axle skewer attachment 135×12, 142×12, 150×12 mm and Trek ABP 142×12
- X-12 (>142 mm) (T1709)
- Suitable for hubs with axle skewer 142×12 mm
- M12x1.5 medium thread (T1710)
- Suitable for hubs with axle skewer attachment 142×12 including Shimano SM-AX65, SM-AX75, SM-AX76 and SM-AX78
- M12x1 metric fine thread (T1711)
- Suitable for hubs with axle skewer attachment 142×12 mm: DT Swiss RWS axle skewer (conical and flat), Syntace X-12 system (Specialized) and various Shimano types
For detailed dimension information on the above thru-axles see: Dimensions of Tacx Trainer Axles
How Do I Know Which Axle I Have?
Generally the size will be stamped on the axle itself. If you are unsure of the size, consult the bike manufacturer or the place the bike was purchased from.
