TT 15, TT 15 mini, and TT 15X Collar Light Sequences
The TT™ 15, TT™ 15 mini, and TT™ 15X  dog collars will display different light sequences to let you know the status of the collar while in use or during charging. The different colors and flashes are described in the tables below.
Light Sequences When In Use:
Single green blinkAcquiring satellite reception
Double green blinkAcquired satellite reception
Triple green blink*Acquired strong satellite reception
Rapid green flashWaiting to pair (T and TT™ collars only)
Solid greenProducing stimulation (TT collars only)
Solid redWaiting for button release (TT collars only)
Light Sequences When Charging:
Solid redCurrently charging
Solid greenFully charged
Flashing redCharge fault (issue with charging the battery)
Light Sequences When Updating Software:
Solid yellowErasing code, loading code to computer
Flashing yellowSystem code missing
Solid redWaiting for a button release to turn off
Light Sequences In Sleep Mode:
Available for the TT 15x/ T5x and TT 15 mini/T5 mini collars only.
Rapid Green, followed by rapid redUnable to put into sleep mode.
Single red blinkSleep mode
*Waiting for the triple blink is not required but will provide the best accuracy.
Related
