GLS™ 10 Sonar Module: Source Not Found Error Message
If a LiveScope™ transducer experiences an error message on a GPSMAP® chartplotter, stating Source Not Found there are a few things to check that may resolve the issue:
With Panoptix™ transducers, ensure sufficient voltage or amperage to the Panoptix transducer's power cable
With LiveScope systems, ensure sufficient voltage or amperage to the GLS™ 10 sonar module
Check for low battery amperage
Verify that the wire gauge used for power cable extension is appropriate for the length used to extend power
Ensure the GPSMAP chartplotter and power supplied to the transducer or GLS 10 share a common ground; see Garmin Marine Network Considerations
Try turning Simulator ON then back OFF to reset layouts; see Using Simulator Mode on Garmin Marine Devices
From a GPSMAP chartplotter, try resetting Station Layouts. Select Options > Settings > System > Station Information > Reset Layouts
Notes:
• The provided solutions apply to all Panoptix transducers or modules that interface via marine network.
• When using a unit that has shortcut keys (1, 2, 3 and 4 buttons), if Panoptix is saved to one of these shortcut keys and are receiving a Source Not Found error, the shortcut key must be re-programmed.
