Keeping Score With the Garmin Golf App
The Garmin Golf™ app can be used to track and keep score of your round of golf. The Garmin Golf app can also be used without a Garmin® golf-capable device for players that still want to track their scores and compare their rank among other Garmin Golf app users. This can also be useful if you forget your Garmin device but still want to track your round.
NOTE: Keeping score without using a Garmin golf-capable device will not provide GPS distance information for the course, and you will only see a basic layout for each hole. If you have the Garmin Golf™ Membership subscription, keeping score on the Garmin Golf app will show Green Contours. For more information, see - Understanding Green Contours and Compatible Garmin Golf Products.
Starting a Round and Keeping Score
Choose an option below for instructions that will guide you through using the Garmin Golf app to keep score.
Starting a New Round
The instructions below will guide you through starting a round of golf on the Garmin Golf app.
  1. Open the Garmin Golf app.
  2. Select Small white ball inside orange circle.
  3. Select Start a Round.
  4. Select the course you are playing. You may need to first select Orange arrow above a line to download the course data.
    NOTE: Press Garmin Golf app magnifying glass icon in the upper-right corner of the screen to reveal the search box to search for courses by name.
  5. Select the tee box you are playing from.
  6. Enter your desired round settings.
    NOTE: The tee box will be filled in automatically based on the previous selection.
  7. Press Start when you are ready to begin your round.
Keeping Score
When you start a round the Garmin Golf app will default to the first hole. This is shown on the bottom middle of the screen with other hole information including the par rating. To change the hole that you are starting on select the hole number and then select the correct hole.
  1. SelectPlus Iconto log your score. This will automatically default to par for the hole.
  2. Select theMinus IconorPlus Iconto decrease or increase your total score for the hole.
  3. Select Three orange circlesto open the menu for fairway hits and number of putts.
    1. Select if you were left, on, or right of the fairway.
    2. SelectGarmin Golf App Plus Iconto log your putts.
      NOTE: The number of putts taken is used for stat tracking only and is not added to the total score.
  4. Select Garmin Golf app back arrow icon or Garmin Golf app forward arrow icon  to change holes.
  5. When finished with the last hole, select Three orange circlesat the top right of the screen.
  6. Select End Round.
  7. Select Save.
Scorecard Features
Now that you have finished saving your scorecard below are other features that you might be interested in.
Related
