The Micro USB Port on My Edge Is Not Working
A non functioning micro USB port found on certain Edge® cycling computers, may result in any of the following symptoms:
Device is not recognized by a computer.
Device does not charge.
Device does not turn on.
USB cable does not plug in correctly.
To ensure that the issue is not related to the device being in a locked up state, or perhaps a malfunctioning USB cable, review the following FAQ: My Garmin Watch or Edge Device Will Not Turn On
If the issue is determined to be a damaged or non-working USB port, you can use our self-service exchange tool. There will be a repair fee to use this service for devices outside of their warranty period. Before you begin, you will need:
Serial Number
This is located on the back of the device. If you cannot read the number you can look up the information in Garmin Connect: Locating Your Serial Number in Garmin Connect
The email address associated with the device.
This should be the email address used to sign into Garmin Connect.
To begin the exchange process see the following link: Edge Self-Service Exchange Program
NOTE: This tool will only work with the following Edge models:
Edge 130 Plus
Edge 530
Edge 830
Edge 1030 Plus
Edge Explore
