Understanding Charges for Tracking on inReach Safety, Essential and Enabled Plans
inReach® satellite communicators include a tracking feature that can share your location via satellite to your LiveTrack™ page or MapShare™ page at specified intervals so others can follow along with your progress.
With the inReach Consumer Safety1 Essential, and Enabled plans, there is an additional cost2 per send/track point when tracking is enabled on the inReach device. Track points are sent every 10 minutes by default. As an example, if your Send Interval is set to 10 minutes and you had tracking on for 1 hour, you could be charged for 7 track points (this includes a starting track point). If tracking is being used daily, these charges can add up quickly.
How Can I Control the Number of Send/Track Points Being Used?
Tracking settings can be adjusted to change how often track points are being sent.
Most inReach devices3 can also be set to only record the track locally on the device without ever sending points via satellite to your LiveTrack or MapShare page, therefore avoiding any tracking charges. This is a good option if you wish to record your trips for your own review, but do not need to share your trip progress with others in real time.
Follow the steps for your device below to adjust the tracking settings.
GPSMAP® 66i, 67i, 86i, and 86sci Satellite Communicators
Press MENU twice to reach the main menu.
Select Setup.
Select Tracking.
Select an option:
Auto Track: Ensure this is set to Off.
Link with Recording: Ensure this is set to Off.
Moving Interval: Set to the desired value to control how often track points are sent if/when you do choose to share your tracking progress.
When the Auto Track and Link with Recording settings are both turned off, track points will only be sent if you select Start Tracking on the device. Your trip can still be recorded locally on the device by using Recording Controls in the main menu. For more details on using Recording Controls, see - Recording an Activity on the GPSMAP 66/67/86 Series.
inReach Explorer® Satellite Communicator
Select Settings.
Select Tracking.
Select Send Interval.
Select the desired value to control how often track points are sent while tracking.
Choosing Off will prevent any track points from being sent, but will still allow the device to record a track internally for your own review.
inReach® Mini 2 Satellite Communicator
Press OK to open the menu.
Select Settings.
Select Tracking.
inReach® Messenger and Messenger Plus Satellite Communicators
NOTE: Tracking information cannot be stored locally on the inReach Messenger or inReach Messenger Plus. As such, using the Tracking function will prompt track points to be sent out at the chosen interval and will lead to additional charges on your inReach bill.
When connected with a smartphone, you can adjust the tracking settings with the Garmin Messenger app by selecting Device > Settings > Tracking, or you can follow the steps below on the inReach device.
From the home screen, press or to scroll through the main menu options.
Select SETTINGS.
Select Tracking .
inReach SE® Satellite Communicator
NOTE: Tracking information cannot be stored locally on the inReach SE handheld. As such, using the Tracking function will prompt track points to be sent out at the chosen interval and will lead to additional charges on your inReach bill.
Select Settings.
Select Tracking.
Select Moving Interval.
inReach SE®+ Satellite Communicator
Select Settings.
Select Tracking.
Select the desired Send Interval value to control how often track points are sent while tracking.
Montana® 700i, 710i, 750i, and 760i Satellite Communicators
Touch to reach the main menu.
Select Setup.
Select Tracking.
Select an option:
When the Auto Track and Link with Recording settings are both turned off, track points will only be sent if you select Start Tracking on the device. Your trip can still be recorded locally on the device by tapping the power button or swiping down from the top of the screen, then selecting the current activity recording. Recording controls can also be found in the main menu under Recorded Activities > Current Activity. For more details on using Recording Controls, see - Recording an Activity on the Montana 700 Series.
1The Safety subscription plan is no longer available for purchase. The Safety plan has been replaced by the Essential plan.
3The inReach Messenger series and inReach SE satellite communicators cannot store tracking data on the device and must send out track points via satellite in order to use tracking.
