Edge® 530
Edge® 540
Edge® 830
Edge® 840 | Edge® 840 Solar
Edge® 1030 | Edge® 1030 Plus
Edge® 1040 | Edge® 1040 Solar
Edge® 1050
Edge® Explore
Edge® Explore 2
Edge® MTB
Pairing an eBike to a Garmin Device
Compatible Garmin devices that feature full eBike support can pair with an eBike to display information such as battery and estimated range. For connectivity type for your device, refer to your owner's manual and search for “Pairing Your Wireless Sensors”.
Approach® S50
Approach® S70 | Approach® S70 - TaylorMade® Edition
D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ G2
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
Descent™ Mk3 | Descent™ Mk3i
Enduro™
Enduro™ 2
Enduro™ 3
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix® E
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner 570
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Forerunner 970
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Venu® 3 | Venu® 3S
Venu® X1
How to Pair an eBike
To get the most out of the eBike activity profile, you can pair your eBike as a sensor to your device.
NOTE: The following steps are generic and will work for most models. If these steps do not work for your model refer to your owner's manual and search for “Pairing Your Wireless Sensors”.
Watches
Access your Settings menu. For specific steps for your watch, see your owner's manual.
Select Sensors & Accessories or Connectivity > Sensors & Accessories.
Select Add New.
Select eBike.
You may need to put your eBike in pairing mode to be discovered by the watch.
Press START/STOP (upper-right button) to confirm.
After the eBike has been paired, the watch can automatically connect during an eBike activity.
Edge Cycling Computers
Select the Menu.
Select Sensors.
Select Add Sensor.
Select eBike.
You may need to put your eBike in pairing mode to be discovered by the Edge.
Select the eBike to confirm.
After the eBike has been paired, the Edge can automatically connect during an eBike activity.
Features Supported After Pairing
Depending on your model of eBike, different data may report to your device. If you are not seeing battery or range data from the eBike, confirm that you have paired the bike correctly, see How to Pair an eBike above. If you are not seeing other metrics, confirm with your eBike manufacturer which metrics are reported by the bike. If you notice that the distance or speed shown on the watch does not seem accurate, you may need to calibrate the wheel size on the eBike. For help with calibration, contact your eBike manufacturer.
NOTE: Not all Garmin devices will have every data field option available. To confirm that your device is compatible refer to your owner's manual and search for “Data Fields”.
Assist Mode
Battery Life
Cadence
Distance
Power
Range
Shifting Information
Speed
Example Data Screens:
