Add, Edit, or Remove Golf Clubs for Your Garmin Golf Product
Many Garmin® golf products have the ability to add clubs to track statistics. Some Garmin products will add clubs through the settings on the product. Other Garmin products that are compatible with the Approach® CT1 tags or Approach® CT10 club sensors will track club information when paired to or connected with the golf product. Refer to your owner's manual for steps on adding clubs to your golf capable product.
Once clubs are added to your Garmin product, you can edit the clubs to change the club type, shaft flex, shaft length, or nicknames within the club list. You can also retire or turn off the active indicator on clubs if you are no longer using them or would like to start over with fresh statistics for a specific club. The sections below outline editing and removing clubs with either the Garmin Golf™ app or your Garmin Connect™ account using a web browser.
If you are using the Approach® CT1 club tracking tags there are editing options available directly on compatible watches. For more information see
below
NOTE: The entire club list will appear on your device. If you are changing to a new set of clubs, we suggest retiring or turning off the active indicator on the old clubs. Setting your clubs to inactive or retiring them will allow you to see stats for the clubs but they cannot be reinstated.
The Approach® CT1 tags each come with a label corresponding with one of 16 club types. This label can be found on the underside of the tag. Regardless of this label, you can edit which tag corresponds to your clubs by following the steps below for your compatible watch.
