Uploading a Geocache Log to Geocaching.com
Once you find a geocache, you can log it and insert a comment in your Garmin Outdoor handheld. Comments can range from how you found the cache, if the geocache needed repair or what you thought of the cache's location. Geocaching.com gives you the ability to upload the geocaches and view these comments using the steps below.
Viewing Geocache Comments Made on Your Handheld
Devices that feature Live Geocaching will automatically upload logs to Geocaching.com. For devices that do not upload these logs automatically, follow the steps below.
Connect your handheld to your computer.
Go to your Dashboard on Geocaching.com.
Select Drafts on the left hand side.
On the Drafts page, select Upload drafts.
Find and select the Garmin drive.
Select the Garmin folder.
Open the file named "geocache_visits.txt".
You will now be able to view the geocaches that you have logged on your handheld. You can then select the Draft to edit your comments or edit the type of log, then submit the Log Entry.
NOTE: It is recommended to delete the "geocache_visits.txt file" once it is successfully uploaded.
