- Select inReach from the home screen.
- Select the tab in the bottom right to get to inReach Weather
- Select New Forecast.
OPTIONAL: Select Forecast Type, Location, or Marine Forecast to change any of these settings.
Forecast Type - Select Basic or Premium.
Location - By default, the device requests weather for your current location. Select this option and follow the prompts to request weather for a different location.
Marine Forecast - Toggle on to receive a marine weather forecast, toggle off to receive a land weather forecast.
- Select Save.
The device will then send a request for the forecast. It can take several minutes to receive the weather forecast data. Ensure you have a clear view of the sky. Once the device receives the forecast, you can view the forecast at any time until all the information in the forecast has expired. The forecast can also be updated at any time.
NOTE: Updating a forecast may incur data charges or additional usage charges depending on your inReach plan. For more information, see - Frequently Asked Questions on Weather for inReach.
You can select a Forecast to view more detailed weather information.
