GPS 15xH/15xL Software Update
Download the latest software for the GPS 15xH/15xL here. You'll want to download both the unit software and sensor configuration (SNSRXCFG) software.
- Setup your sensor by wiring the device as shown in GPS 15xH/15xL Technical Specifications Figure 1 and run SNSRCFG
- Choose the GPS 15xL and click OK
- Use Comm/Setup, select the correct com port and Auto for baud rate and click OK
- Use Config/Switch to NMEA mode and click through the pop-ups
- Use Comm/Connect (must be successful in order to continue - if not, correct the wiring and repeat the steps above)
- Use Config/Switch to Garmin Mode
- Run Updater.exe, choose 38400 for the baud rate, choose the correct com port and continue with the firmware update
- Connect the next device to be updated and continue at step 4
If these devices are definitely in NMEA mode (normally the case), you may use the following, abbreviated procedure:
