MOB Options and Settings for the quatix 6 and quatix 7
Understanding "MOB" (Man Overboard) options and settings
The Man-Overboard (MOB) function is a common feature for Marine GPS units. When the MOB button is pressed, the GPS automatically marks a waypoint at the current location and allows you to enable a "Go-To" navigation line to take you back to the initiated MOB location.
If the GPS device is connected to a Garmin® autopilot using NMEA 2000, the GPS device will present a prompt to enable the autopilot. If the autopilot is enabled, it will force the boat to perform a Williamson maneuver to return to the location of where the MOB was initiated.
How to use "MOB" (Man Overboard) on a quatix® 6 watch | quatix® 7 watch
Marking and Starting Navigation to a Man Overboard Location:
You can hold MOB to save the current location as a man overboard (MOB) location, and automatically start navigation back to it.
From the watch face, press START “long hold”. The quatix will acquire MOB location and Navigation information appears. Use the compass and navigation arrow to locate MOB.
TIP: Customize the hold function of the keys to access the MOB function (Customizing the Hot Keys)
If wanting to use a saved MOB > select activity Navigate
Select Last MOB
Select Navigation > Last MOB
