(2023) Service Bulletin 22124 Rev B: GI 275 Multi-function Instrument Installation in Airbus AS350 Series and System Software Version 2.60
PRODUCTS AFFECTED:
GI 275 Multi-function Instruments installed under the GI 275 Part 27 AML STC SR01980WI are affected.
CERTIFICATION AUTHORIZATION:
STC SR01980WI
COMPLIANCE:
Optional: STC Service Bulletin 22124 may be incorporated at the owner’s discretion.
PURPOSE:
This STC Service Bulletin provides notification of an update to STC SR01980WI Master Drawing List Revision 4.
This STC update adds approval for the installation of the GI 275 Multi-function Instrument into Airbus AS 350 BA, AS 350 B2, and AS 350 B3 Series rotorcraft. This STC update also adds approval for GI 275 Software Version 2.60 which provides the following updates:
- Added Miscellaneous Field display on the HSI and HSI Map pages
- Added the ability to re-arm the optional 100ft / 30m Radar Altimeter aural callout for Rotorcraft Configurations
- Improved the RP mode engagement button to top level menu
- Improved the Bluetooth output data with various GPS sources
- Added digitally signed database application
NOTE
Database sync routing is affected by this change. Systems with GTN™ (v6.72 or earlier) or GPS 175/GNC® 355/GNX™ 375 (v3.20 or earlier) interfaced to G500(H)/G600/G700 TXi (v3.50 or later) or GI 275 (v2.60 or later) no longer support database sync. Databases will need to be loaded onto each GTN and GPS 175/GNC 355/GNX 375 unit. This limitation will be fixed in future GTN and GPS 175/GNC 355/GNX 375 software versions.
