Convert GPX File to ADM Using Garmin BaseCamp
There may be times that you want to use GPX user data in a Garmin chartplotter. Some chartplotters can only use ADM files so the GPX file needs to be converted first before you can use it.
As HomePort™ software is no longer available, you can convert the GPX file to ADM using BaseCamp™ software which is very similar.
Both steps of this process are outlined below.
Importing GPX File(s) Into BaseCamp Software
- Download BaseCamp software from here.
- Open BaseCamp program.
- Select the desired folder (
) or list (
) to add the GPX data to.
- Select File from the top toolbar.
- Select Import into ['Name'].
- Browse to the GPX file location from the Import File window.
- Select Open (Windows) or Import (Mac).
The GPX data should now be contained in the selected folder or list.
Complete steps 3-7 for any additional files you want to import. When finished importing the desired files, proceed with the transfer steps below.
Transfer Imported GPX File(s) To a Chartplotter
- Remove the microSD card from the chartplotter.
- NOTE: The card has to come from the chartplotter so it has its GarminDevice.xml file on it.
- Insert the microSD card into the computer, or into a connected card reader.
- In BaseCamp™, select the folder (
) or list (
) containing the imported data you wish to transfer.
- NOTE: To transfer all saved data, select My Collection.
- Select Device (Windows) or Transfer (Mac) from the top toolbar.
- Select Send to Device.
- Select Send ['Name'] to Device.
- Select the chartplotter to send the data to.
- Mac Users: You also need to select checkboxes for the items to transfer.
- Select OK (Windows) or Send (Mac).
The data should now be written to the micro/SD card as an .ADM file.
