Xero S1 Battery Information and Charging Recommendations
Battery Life:
The Xero® S1 trapshooting trainer is expected to last 8 rounds in Trap or Upland Mode at 25 shots per round. A full charge should last about 2.5 hours depending on various factors like shooting alone or as a group. It has a built-in battery save feature, a screen timeout after 5 minutes of inactivity during a round. Just tap the screen to resume. If you are not in a round it will power off after 5 minutes of inactivity.
It uses the most power waiting or processing shots because the radar is running. Completing the round quickly will help prolong the battery life. Reviewing scorecards and adjusting settings while outside a round uses very little power.
Charging Recommendations:
Use the 2 Amp AC Charger and micro USB cable that come with the Xero S1 trainer at temperatures from 45ºF to 109°F. It charges more efficiently when powered off. Using the provided chargers will take approximately 3 hours to fully re-charge the battery.
Use while Connected to the Charging Cable:
The Xero S1 trainer will continue to function as normal when connected to the charging cable and AC power. It cannot be used for Trap or Upland Mode while connected to the computer.
Note: When the device is fully charged, the status light on the Xero S1 trainer will go out
