Understanding Green Contours and Compatible Garmin Golf Products
With a Garmin Golf™ Membership Subscription, you will be able to use Green Contour Data on both your compatible Garmin® device and in the Garmin Golf™ app. Green Contour Data allows you to know the topography and slope of the green at a glance. Not only will this help you determine your putting line, but it will also allow you to develop better strategies for attacking the greens and improve your short game.
Benefits For Golfers
  • Convenient and accurate 3D map of greens.
  • Help develop a smarter hitting strategy.
For more information, see our Garmin Technology page: Green Contour Data.
Requirements for Green Contours
Once you have met the above requirements, Green Contours will show automatically while viewing the green on the Garmin device. See the owner's manual for your device for information on accessing the green view.
NOTE: The Approach® Z82 automatically changes to the green view when on the green.
Compatible Devices
  • Approach® G80 golf handheld
  • Approach® S44 watch
  • Approach® S50 watch
  • Approach® S60 watch
  • Approach® S62 watch
  • Approach® S70 | Approach® S70 - TaylorMade® Edition watches
  • Approach® Z82 golf range finder
  • D2™ Mach 1 | D2™ Mach 1 Pro watches
  • Descent™ Mk3 | Descent™ Mk3i watches
  • Enduro™ 2 watch
  • Enduro™ 3 watch
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition watches
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition watches
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition watches
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition watches
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition watches
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition watches
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition watches
  • fēnix® 8 Pro - AMOLED | fēnix® 8 Pro - MicroLED watches
  • fēnix® E watch
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2) watches
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition watches
  • quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition watches
  • tactix® 7 - AMOLED | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition watches
  • tactix® 8 - AMOLED | tactix® 8 - Solar watches
  • Venu® 3 | Venu® 3S watches
  • Venu® X1 watch
What Do Green Contours Look Like?
There are two views for Green Contours: slope and elevation.
Slope Percentage
  • The arrows on the Green Contour show the direction the ball will break as it moves over the green.
  • Green Contours will show colors on a heatmap of the green. The colors will help your determine the severity of the slope at a glance. White and blue indicate the least steep slopes. Orange and red indicate the greatest sloping.
Example of Slope
Green Contours Slope
Scale
Bar graph with multi-colored scale
Elevation Map
  • The elevation map shows the topographic lay of the green.
  • There is more elevation change with a higher concentration of lines.
Example of Elevation
Green Contours Elevation
Related
