How to Remove and Replace the Adhesive Mount for a Garmin Dash Cam
The following Garmin Dash Cams come with an Adhesive Mount:
  • Garmin Dash Cam™ Mini 3| Garmin Dash Cam™ Mini 2 | Garmin Dash Cam Mini™ driving recorders
You may use adhesive removal products sold in most hardware stores to remove the adhesive from your vehicle's windshield or dashboard.  If additional leverage is needed, dental floss can be used in a side-to-side motion between the adhesive mount and windshield surfaces.
These products are intended to help remove the adhesive mount without damaging any surfaces. It is recommended to first apply the adhesive remover in a less visible area to test for color damage. Once removed, the adhesive itself will not be reusable.
A replacement mount can be purchased from Garmin.com.
