Editing a Course Using the Garmin Connect App
Once you have saved courses in the Garmin Connect™ app, you can edit your courses as needed.
Editing a Course in the Garmin Connect App
Open the Garmin Connect app.
Select More (bottom right).
Select Training & Planning.
Select Courses.
Select the course you would like to edit.
Tap
(upper right corner) then tap Edit:
Select
to add more course points.
Select
to access more options for editing the course.
Swipe up from the bottom of the screen to access and edit the course name, course type, privacy setting, or goal pace/speed.
To change the location of a point you have already placed, press and hold on the point then drag it to a new location.
Once you are done editing your course, select Done or Save.
When naming courses, keep in mind that most devices have a limit where they only look at the first 15 characters in the name of a course. If there are multiple courses where the first 15 characters are the same, the device will think they are the same course. To work around this limitation, make sure the names vary within the first 15 characters.
NOTE: After making any change to a course, even if only to reverse the direction of the course, the distance will be recalculated after the edit has been saved. The newly-calculated distance may not be equal to the original distance measured by your Garmin device.
