Unable to See Weather Data on the ActiveCaptain App
The ActiveCaptain app does not support the ability to view or stream weather information.
For users who have the legacy application, BlueChartMobile 2.0 with a valid premium weather subscription, you will still be able to view and stream weather data to your compatible chartplotter using the BlueChartMobile app. The ActiveCaptain app and BlueChartMobile app can be run simultaneously on the same device, however the app in the foreground will always take priority. If it is desired to use both apps simultaneously, without issue, two smart devices would be required; one for each app.
