Battery Saver Mode on Venu 2 Series and Venu Sq 2 Series
The Venu® 2 and Venu® 2S watches support a feature called Battery Saver. Enabling this feature changes the behavior of the watch and disables specific functionality to prolong battery life.
Enable Battery Saver:
  1. Press and hold the bottom button.
  2. Select Gear icon for Settings.
  3. Select Battery Manager.
  4. Select Battery Saver to On.
    • You will see a list of features that are going to be disabled with Battery Saver enabled.
  5. Select the Checkmark to confirm.
Battery Saver Toggled on Green
This will extend the time between charges. You will see the expected number of days the battery will last before, and the setting changes made on the device while Battery Saver is enabled.
NOTE: A Low Battery notification will appear on your watch when it has drained to 10% remaining.
Disable Battery Saver:
  4. Locate Battery Saver and toggle it off (gray).
Battery Saver Toggled Off
Related
