Alpha 300 or Alpha 300i Not Acquiring GPS Satellites
If your Alpha® 300 or Alpha® 300i dog tracking handheld is not acquiring satellites you should perform the following:
If you are in the field and do not have access to perform a software update skip to step 3, otherwise continue with step 2.
Perform a software update to ensure you are on the latest software available Software Updates for Alpha 300 and Alpha 300i
If, after performing a software update and with a clear view of the sky, you are still unable to acquire a GPS satellite fix you can enable Multi-GNSS on your handheld by:
Select Setup
Select System
Select Satellite
Select Satellite System
Select Multi-GNSS
If you did not perform the software update in step 2, when you have access return to step 2 and perform a software update.
