How to update the software on the Experimental G5
G5 for Experimental Aircraft Download: link
The software must be downloaded to a Micro SD Card no larger than 32 GB.
- Download the self-extracting update file onto your hard drive.
- Insert a FAT32-formatted micro SD card with at least 20 MB of free space into your card reader.
- Open the self-extracting update file and follow the instructions provided by the installer application. You will be prompted to specify the drive letter of the SD card you wish to use for the update. When the transfer is complete, safely eject the SD card.
- Apply power to your G5 Electronic Flight Instrument.
- Insert the SD card containing the software update. You will be prompted to confirm before the update is installed.
- During the software update, the G5 will indicate ''Loading''. Do not remove power during the update process.
- When the update is completed, the G5 will reset itself and turn on normally.
