The Micro USB Port on My Varia Radar/Light Is Not Working
A non functioning micro USB port found on certain Varia™ models, may result in any of the following symptoms:
Device is not recognized by a computer.
Device does not charge.
Device does not turn on.
USB cable does not plug in correctly.
If you have tried a different USB cable and the issue is determined to be a damaged or non-working USB port, you can use our self-service exchange tool. There will be a repair fee to use this service for devices outside of their warranty period. Before you begin, you will need:
Serial Number
This is located on the back of the device.
The email address associated with the device.
This should be the email address used to sign into Garmin Connect.
To begin the exchange process see the following link: Edge Self-Service Exchange Program
NOTE: This tool will only work with the following Varia models:
Varia™ RVR315 rearview radar
Varia™ RTL515 radar tail light
Varia™ UT800 smart headlight
