How to Use Easy Route Shaping on a Created Route
The calculated route can be manually shaped to change its course. Adding a shaping point will allow you to customize the calculated route to take a certain road or go through a certain area without adding a via point or destination to the route.
To Manually Shape the Route:
1. Touch anywhere on the map when in an active route
2. Touch  to view the whole route
3. Select a location on the map. Use the + and - buttons to zoom in and out if needed
    • Allow the route time to calculate
4. Touch Shape Route
5. Touch Go!
This will shape the route to the way you want it to go. You can add up to 30 shaping points to your route. Repeat the steps, as necessary.
These Changes can be Saved to Your Route for Future use by Going Into Route Planner:
1. Touch the Back arrow to return to the Where to? and View Map screen
2. Touch Route Planner
3. Touch My Active Route
4. Touch Save
5. Type the desired name for the route, then touch Done
The custom route will now be saved as a trip in Route Planner.
