Vehicle Information Out of Date Error Message when Updating a Honda Vehicle
The following message will display in Garmin Express if more than 24 hours have passed between the following steps 1 (inserting the USB flash drive into the vehicle) and 2 (using Garmin Express). If it has been less than 24 hours and you are receiving this message, verify the date and time are correct on the vehicle clock. An incorrect data and time can cause an incorrect time stamp.
Canada and Border States
Return to the vehicle and rewrite the information from your navigation system to the USB flash drive to correct this.  See the instructions below for your vehicle.
NOTE: See Using the Same USB Flash Drive for the Honda Map Update before proceeding.
2018 and Newer Honda Accords and Odysseys
1. Plug the USB flash drive into the vehicle
2.Touch Navigation
3. Touch the menu button ( 3 dots) in the upper right corner
4. Touch Settings
5. Touch Map & Vehicle
6. Touch Update Maps
7. Touch Start Map Update Process
8. Follow the onscreen prompts
2019 and Newer Honda Pilots, Insights, and Passports
2. Touch Navigation
3. Touch the menu button (3 dots) in the upper right corner
4. Touch Settings
All Other Models
2. Touch Navigation
3. Touch Settings
4. Touch Device
5. Touch Update Map
6. Follow the onscreen prompts
Contact Product Support if the above troubleshooting fails to resolve the issue.
