Edit Arrow Profile Range Pins or Fixed Pins for the Xero A1i
If you need to edit an arrow profile to adjust the current range pins or fixed pins you first need to make the arrow profile active.
To edit the activate arrow profile on the Xero® A1i bow sight:
  1. From the main menu, select Xero A1i Arrow Profile Menu Icon
  2. Select an arrow profile
  3. Select Activate
Once the correct arrow profile is active go to the pins you would like to update.
Fixed Pins
Calibrating Additional Ranges
