The Collections Manager on the GPSMAP 86 series
The Collections Manager allows a user to select which Collections are active on a GPSMAP 86 when synced with the Garmin Explore App, which helps to organize what user data is visible on the handheld.
For more information on collections, see - Garmin Explore Collections
The recently added Collections Manager via a recent software update for the GPSMAP 86. If the Collections Manager icon is missing on the main menu, add using the following instructions:
Adding the Collections Manager to the Main Menu
Power on the GPSMAP 86
Go to the Main Menu
Press MENU
Press ENTER on Change Item Order
Scroll down to the bottom of the page and select Add Page
Select Applications
Select Collections Manager
Accessing and Using the Collections Manager
Press the MENU button twice to reach the Main Menu
The Collections synced to the GPSMAP 86 will display additional information and options
Each Collection lists the number of waypoints, tracks, routes, and activities
The message No Collections found indicates the handheld needs to be paired and synced with the Garmin Explore App. For steps, see Related Content
To enable or disable an individual Collection, select the toggle for it:
The Collection is enabled, and the user data is listed and usable on the handheld
The Collections is disabled; this hides user data on the handheld.
To enable or disable all Collections, press the MENU button and Enable All or Disable All
Enabling or Disabling a Collection
When a collection(s) is/are enabled or disabled, the data contained within it will either be available or not available within its respective menu:
Tracks under Saved Tracks
Waypoints under Waypoint Manager
Routes under Routes Planner
Activities under Recorded Activities
