Creating Custom POI Files
Creating Custom POI Files:
Advanced users can create their own .csv and .gpx files that contain Custom POIs (points of interest) for use on compatible Garmin devices with MP3 players. Both .csv and .gpx files are loaded to the device using the Garmin POI Loader application. After processing the files, POI Loader uploads a single file called Poi.gpi to the device.
All POI-related files should be stored in 1 main directory on the computer. POI Loader requires a folder to load the POI files. Once a POI file has been created, a folder will need to be created for the file. One level of sub-folders is allowed for organizing files and creating POI categories. The POI Loader combines all files in the main folder and its sub-folders to create 1 file. Each time POI Loader sends POIs to a device the existing Poi.gpi file is overwritten. Using a pre-existing folder on the computer may cause POI Loader to include spreadsheet files not intended for POI Loader.
Creating Basic POIs:
Refer to these FAQs for help with creation:
NOTE: The file name for the .csv file cannot contain commas, or special characters.
Creating Custom POIs Using a Text Editor.
Creating Custom POIs in Microsoft Excel.
Creating Custom POIs in BaseCamp™ Software.
Creating Proximity Alerts for Custom POIs in POI Loader.
Creating Icons for Custom POIs.
*Except for the basic handhelds and older Rino® 2-way radio GPS devices, all current outdoor and automotive products are compatible with Custom POIs. TourGuide POIs are only compatible with MP3-capable nüvi® and zumo® devices. Check the particular Garmin model’s spec sheet for Custom POI compatibility.
