Add, Rearrange, or Delete Shortcuts on a zumo 396
Some automotive devices offer you the ability to add shortcuts to the Where To? menu. This allows for faster access to categories you frequently search.
To add a shortcut:
- Touch Where To?
- Touch Add Shortcut
- You may need to scroll down
- Select the Shortcut or Search Tool to add
- Available shortcuts: Favorite Search1, Category2, and Saved Place3
- Available Search Tools: Foursquare, Tripadvisor, Parking, Trip Planner, Address, Intersections, Cities, and Coordinates
The shortcut now appears in the Where To? menu until it is removed. Repeat the above steps to add more shortcuts. Up to 36 shortcuts may be added to the Where To? menu. If you have already added 36 shortcuts, the Add Shortcut icon will not display.
To remove a shortcut:
- Touch Where To?
- Touch the menu button (three horizontal lines)
- Touch Remove Shortcuts(s)
- Touch the shortcut to be removed
- The Go Home, Saved, Recent, and Categories shortcuts are the only shortcuts which may NOT be removed
- Touch the shortcut again to confirm its removal
- Repeat steps 4 and 5 for each additional shortcut to be removed
- Touch Done to save all changes
- Touch Cancel to undo all shortcut deletions
The shortcuts removed should no longer appear in the Where To? menu.
The shortcuts listed on the Where To? menu can also be rearranged on your device. To move a shortcut icon, simply touch and hold on the icon then drag it to the desired location.
1Selecting Favorite Search will prompt you to enter search terms such as a specific word or a particular business/chain name.
2Selecting Category allows you to select among the following Point of Interest (POI) categories: Motorcycle Locations, Restaurants, Shopping, Everyday Life, Gas Stations, Banks & ATMs, Parking, Rest Areas, Art & Entertainment, Attractions, Recreation, Medical Care, Transit, and Lodging. Some of these POI categories also allow you to select among further subcategories if you wish to narrow the search. For example, Barbecue, Car Washes, Movie Theaters, and so on.
3Selecting Saved Place allows you to create a shortcut to any of the locations you have stored in the Saved section. This is ideal for locations to which you frequently travel. Adding a shortcut allows you to select a favorite location without having to browse through those Saved locations.
