How To Use Virtual Power with Basic Trainers
What is Virtual Power?
The Tacx Training™ app estimates your power based on the speed from a compatible sensor and the resistance level of your trainer. This estimation is based on the trainers power curve. The power curve chart (below) shows you the power (watts) required to achieve a given speed at each resistance setting and is unique for each basic trainer model. Virtual power is an estimate of your power based on the speed and resistance, and is not a precise measurement.
Graph showing relationship between speed and power for different resistance levels
What Are My Training Options?
Virtual power allows you to:
  • Ride Tacx Films in the Tacx Training app.
  • Ride a GPS track in the Tacx Training app.
  • Ride with the Zwift app.
  • Ride with the TrainerRoad app.
  • Keep track of your speed and estimated power.
  • Cadence data requires an optional cadence sensor.
When using the Tacx Training app or Zwift, it is best to keep the resistance lever on position 2.
Instructions
  1. Mount the speed sensor on the rear wheel hub according to the sensor’s manual.
  2. Open the app you wish to use.
  3. Pair the speed sensor in the app.
  4. Select your wheel diameter.
  5. Select the Tacx Boost as trainer.
  6. The sensor is connected.
  7. When using the Tacx app or Zwift app, set the resistance lever on your handlebar to position 2.
Related
