My Approach G10 is in the Wrong Language
If your Approach® G10 golf device is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the watch, follow the steps for resetting the device.
Changing the Language
  1. Turn on the Approach G10 by holding Up.
  2. Press Down 2 Times.
  3. Press OK.
  4. Press Down 5 Times.
  5. Press OK.
  6. Press Up until you see the language you would like.
  7. Press OK.
You have now changed the language on your Approach G10 device.
If you were unable to change the language on your device using the steps above, the below instructions will guide you through the reset steps. You will be prompted to select a language after the reset, during initial setup.
Resetting the Approach G10
All user settings, with the exception of saved scorecards, will be restored to defaults with a master reset.
  1. Power off the unit by holding Up until it is off.
  2. Press and hold Back and OK.
  3. Press and hold Up until the Garmin logo appears on the screen then release Up.
  4. Continue holding Back and OK for 10 seconds.
  5. Release OK.
  6. Release Back 5 seconds after releasing OK.
The Approach G10 device will now reset, and a new language can be selected during the initial setup.
